Displaying POS Register
https://help.tallysolutions.com/docs/te9rel55/Advanced_Features/Advanced_Inventory_Features/Displaying_POS_Register.htm
POS Register lists all transactions made over a particular day and by default displays the last invoice entry date of a POS invoice. Each POS Invoice is further drilled down to obtain the lowest level of information.
To view the POS Register
1.    Go to Gateway of Tally > Display > Accounts Books > POS Register. The POS Register appears as shown below:
Note: The POS Register will be available, only if the option Use for POS Invoicing is enabled in Voucher Type and at least one entry is made.
2.    Click F1: Detailed to view the report in detailed mode.  The POS Register appears as shown below:
3.    Click F12: Configure to configure the report.
4.    Set Show Inventory Details also to Yes and view the List of All POS Vouchers with Inventory details.
