https://help.tallysolutions.com/docs/te9rel55/Reports/Basic_Features_of_Displaying_Reports.htm
Basic Features of Displaying Reports
Tally.ERP 9 creates the books of accounts and the financial statements based on the vouchers entered till date. You can then customise the appearance of reports as required.
For example, you can compare different companies, periods of the financial year, groups and ledgers.
Press Enter after highlighting the item in a report, to navigate to the next level of detail till you reach an individual voucher. Similarly, you can navigate back to higher levels by pressing Esc. The special features available for a displayed report are indicated on the button bar, which can be operated by a single- click of the mouse.
Accessing reports
The Gateway of Tally menu provides access to all the financial reports listed in the Display Menu.
For example, if you want to view the Sales Register:
Go to Gateway of Tally > Display > Account Books > Sales Register.
Tally.ERP 9 will display the report for the currently selected period.
