https://help.tallysolutions.com/docs/te9rel55/Maintaining_Company_Data/Maintaining_Group_Company/Creating_and_Altering_Group_Company.htm
Maintaining Group Company
The accounts of individual companies that belong to the same management can be consolidated to present a single financial report of the group of companies. You can view the performance of the group as a whole when required.
Creating Group Company
A Group Company can be created only for those companies that have been loaded in Tally.ERP 9.
To create a group company
1.    Click F1: Select Cmp to select the required companies to be loaded. Tally.ERP 9 displays the loaded companies in Gateway of Tally screen.
2.    Click F3: Cmp Info to view the Company Info menu, and click Create Group Company. The Group Company Creation screen appears as shown below:
Note:
♦   Create Group Company option is available only when two or more companies are loaded.
♦   A constituent company can be a member of more than one group.
♦   A group company can also be a constituent of another group company.
3.    Select the member companies from the List of Companies menu to create the group company.
Note:
♦   Entering a transaction is possible only in the member companies, and not group company.
Altering Group Company
You can add, remove, or edit details of the member companies by altering the group company.
To alter a group company
1.    Go to Gateway of Tally > click F3: Cmp Info > click Alter.
2.    Select the group company in the Group Company Alteration screen as shown below:
Reload the company to see the changes done to the group company.
See also
Creating a Company on Tally.Server 9
