https://help.tallysolutions.com/docs/te9rel55/Payroll/ESI_Process.htm
Processing Employer ESI Contribution (Payroll)
Like provident fund, ESI amounts are calculated separately. However, you need to pay the amount using a single payment voucher.
To process the Employer ESI Contribution
1.    Go to Gateway of Tally > Payroll Vouchers > Ctrl + F4: Payroll.
2.    Press F2 to change the Voucher Date.
3.    Click A: Payroll Auto Fill.
4.    Select the required process in Process for field.
5.    Enter the From and To date.
6.    Select the appropriate Employee Category.
7.    Select the Employee/Group from the List of Employees/Group.
8.    Select the appropriate Payroll Ledger from the List of Ledger Accounts.
9.    Press Enter to go to Payroll Voucher Creation screen.
10.  Press Enter to save.
Note: ESI monthly wage threshold is increased from Rs. 15,000/- to Rs. 21,000/- effective from 1st Jan 2017.
