https://help.tallysolutions.com/docs/te9rel55/Tax_India/VAT/Maharashtra/MH_JV_Rev_input_tax.htm
Reversing Input Tax (Maharashtra)
In Tally.ERP 9, you can record a journal voucher to account for the reversal of input tax.
To create a journal voucher of reversal of input tax
2.    Click J: Stat Adjustment to enable required options in the Stat Adjustment Details screen.
o     Select Type of duty/tax as VAT.
o     Select Reversal of Input Tax as Nature of adjustment.
o     Select Excess Claimed Earlier in the Additional Details field. The Stat Adjustment Details screen appears as shown below:
o     Press Enter to save, and return to the voucher.
3.    Debit the expense ledger, and enter the value.
4.    Credit the VAT ledger.
o     Enter the Rate, and Assessable Value in the VAT Details screen.
5.    Press Enter to save.
