https://help.tallysolutions.com/docs/te9rel55/Voucher_Entry/Advanced_Voucher_Entry/Using_Cost_Categories_and_Cost_Centres.htm
Using Cost Categories and Cost Centres
Cost Centers can be allocated in the vouchers. Activate Cost Centre for the Ledger Accounts that are used in voucher entry.
Note: Activate Maintain cost centers and Maintain more than one payroll or cost category in F11:Features > F1:Accounting Features.
Applying Cost Centres to Ledger Accounts
To apply cost centres to ledger accounts,
For example, enable Cost Center for Payment ledger – conveyance account.
     Go to Gateway of Tally > Accounts Info > Ledgers > Create/Alter
     Set the option Cost centres are applicable to Yes.
Cost Centre Allocation in Voucher Entry
Cost Centre allocations have to be done in the pop-up sub-screens in the main voucher entry screen. The sub-screen is displayed after the amount fields pertaining to the ledger for which cost centers have been activated. Hence, the following is the sub-screen for the ledger Conveyance A/c.
The entire objective of creating Cost Centres is to allocate expenses and revenues to Cost Centres.
After allocating the Cost Centers, the payment voucher entry screen is displayed as shown.
