https://help.tallysolutions.com/docs/te9rel55/Advanced_Features/Advanced_Inventory_Features/Creating_Ledgers_for_Job_Costing.htm
Accounting Ledgers for Job Costing
Accounting masters can be enabled for job costing by setting the option Cost Centres are applicable? to Yes.
For example, to account for project inspection charges, create a ledger under Indirect Expenses as shown below:
Note: The option Cost Centres are applicable? will be available only if the option Provide Advanced Information in Masters is enabled in the Master Configuration (F12: Configure) screen.
