https://help.tallysolutions.com/docs/te9rel55/Tax_India/VAT/Delhi/Increasing_Input_Tax.htm
Recording Increase in Input Tax (Delhi)
To record a transaction with increased input tax value, you can create a journal voucher with the necessary Stat Adjustments, debit your VAT ledger, and credit the relevant purchase ledger.
To account for increase in input tax
2.    Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o     Select Type of duty/tax as VAT.
o     Select Increasing Input Tax, as the Nature of adjustment.
Note: Based on the selection made for Nature of Adjustments, the Additional Details option either appears or disappears.
o     Press Ctrl+A to return to the voucher.
3.    Debit the input VAT ledger and enter the amount.
o     Enter the Rate and Assessable Value in the VAT Details screen.
4.    Credit the purchase ledger.
o     Select the Name of Item and enter the Amount in the Inventory Allocations screen.
5.    Enter the tax Rate and Assessable Value in VAT Details screen. The journal voucher appears as shown below:
6.    Press Enter to save.
