https://help.tallysolutions.com/docs/te9rel55/Voucher_Entry/Order_Processing/Creating_a_Purchase_Order.htm
Recording a Purchase Order
A purchase order is placed by a business entity with a supplier for the delivery of certain goods at a given price and time. Purchase order processing has to be enabled in order to create a purchase order.
To enable purchase order processing
1.    Go to Gateway of Tally > F11: Features > Inventory Features.
2.    Set Enable purchase order processing? to Yes.
3.    Press Ctrl+A to accept.
To create a purchase order
1.    Go to Gateway of Tally > Inventory Vouchers > Ctrl+F2 > F4: Purc. Order to view the Order Voucher Creation screen.
2.    Enter the Party's A/c Name.
3.    Enter the Order No.
4.    Select the Name of Item from the List of Stock Items, or press Alt+C to create a new stock item.
5.    Enter the Quantity of the item, as required.
6.    Enter the Rate of the item. The Order Voucher Creation screen appears as shown below:
7.    Press Ctrl+A to accept.
Now, you can send the purchase order for an item to your supplier.
