https://help.tallysolutions.com/docs/te9rel55/Tax_India/VAT/Delhi/Decrease_of_Input_Tax.htm
Recording Decrease in Input Tax (Delhi)
To record a transaction with decreased input tax value, you can create a journal voucher with the necessary Stat Adjustments, debit your CST ledger, and credit the input VAT ledger.
To create journal voucher for decreasing input tax
2.    Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o     Select the option VAT in the Type of duty/tax field.
o     Select the option Decrease of Input Tax in the Nature of adjustment field.
o     Select the option Against CST in the Additional Details field.
o     Press Enter to save and return to voucher screen.
3.    Debit the CST ledger created under the group Duties & Taxes.
o     Enter the Rate and Assessable Value in the VAT Details screen.
5.    Credit the input VAT ledger created under the group Current Assets.
6.    Press Enter to save.
