Creating Stock Item (scrap, by-products, co-products)
https://help.tallysolutions.com/docs/te9rel55/Job_Work/Stock_Item_Scrap_By_products_Co_products.htm
Each item is required to be accounted for, and receipt or issue needs to be created. In fact, you will create a stock ledger account for each item and Tally calls this account Stock Item.
To create the stock item
1.    Go to Gateway of Tally > Inventory Info. > Stock Items > Create.
2.    In Name field enter the stock item Name. For example, Aluminium Scrap.
3.    Group the stock item Under the stock group Scrap (if stock group is not created use Alt+C from Under field to create the stock group).
4.    In Units field select the applicable unit of measurement. For example, Gm.
5.    Press Enter to save
Scrap - if Excise Applicable
2.    Enter the Stock Item Name, Group, Units, and enable the option Set/alter excise details.
3.    In Excise Details screen select Reporting UOM, enable Set/Alter Duty Details to select the duties applicable for the stock item and select the Stock Item Type - others.
4.    Press Enter to save.
