Tax on Purchase from Unregistered Dealers (Madhya Pradesh)
https://help.tallysolutions.com/docs/te9rel55/Tax_India/VAT/Madhya_Pradesh/mp_tax_on_urd_pur.htm
You can account for tax on purchases from unregistered dealers by creating a journal voucher.
To create tax liability on purchase from unregistered dealers
2.    Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o     Select the option VAT in the Type of duty/tax field.
o     Select the option Tax on URD Purchase in the Nature of adjustment field.
o     Press Enter to save and return to the voucher screen.
3.    Debit the ledger created under the group Indirect Expenses and enter the amount.
4.    Credit the purchase tax/VAT ledger created under the group Duties & Taxes.
o     Enter the Rate and Assessable Value of the item purchased, in the VAT Details screen. The VAT Details screen appears as shown below:
5.    Enter Narration, if required.
6.    Press Enter to save.
