https://help.tallysolutions.com/docs/te9rel55/Creating_Masters/Inventory_Info/Altering_a_Stock_Group.htm
Altering a Stock Group
This option allows you to view the existing Stock Group in edit mode, here you are allowed to change the various information.
To alter a Stock Group
1.    Go to Gateway of Tally > Inventory Info. > Stock Groups > Alter (under Single Stock Group).
2.    Select the Stock Group from the List of Groups. The Stock Group Alteration screen is displayed as shown.
Make the necessary changes and click Yes to accept or press Ctrl+A to Save.
Deletion is possible only in the mode,. For deleting the Stock Group, Press ALT+D.
Note: You cannot delete a stock group, if it is used by any sub groups or stock items. In order to delete the Stock Group, first delete the relevant sub groups and Stock items.
Buttons specific to stock group Alter mode:
Buttons
Short cut Keys
Description and Keys
C: Category
CTRL+C
Allows you to Alter a Stock Category.
I: Items
CTRL+I
Allows you to Alter a Stock Item.
U: Units
CTRL+U
Allows you to Alter a Unit of Measure.
O: Godown
CTRL+O
Allows you to Alter a Godown.
V: Vch Types
CTRL+V
Allows you to Alter a Voucher Types
Note: Category and Godown buttons are visible only if you have opted for the same in F11: Features.
Altering Multiple Stock Groups
1.    Go to Gateway of Tally > Inventory Info. > Stock Groups > Alter (under Multiple Stock Groups).
2.    Select the Stock Group from the List of Groups. The Multi Stock Group Alteration screen appears as shown below:
Make the necessary changes and click Yes to accept or Press CTRL+A to save.
Note: You cannot delete a Stock Group from multiple mode.
Buttons specific to Multi stock group Alter mode:
Buttons
Short cut Keys
Description and Use
F4: Parent
F4
Allows you to select Stock Group from Under Group Field for changing the parent of sub groups.
F4: Parent
CTRL+F4
Allows you to select parent [Stock Group] from List of Group. You can alter the sub groups of selected Stock Group.
F6: Skip Names
F6
Cursor will not go to Column Name of Stock Group. If you want to alter only the details of “Under” Column and “Items are addable” then you can skip names.
F7: Skip Parent
F7
Cursor will not go to column Under. If you do not want to alter parent then you can skip parent.
F8: Skip Details
F8
Cursor will not go to column Items are addable. If you do not want to alter Items are addable then you can skip details.
C: Category
CTRL+C
Allows you to Alter a selected stock Category in Multi-stock category screen.
I: Items
CTRL+I
Allows you to Alter a selected Item in Multi Stock Item screen.
O: Godown
CTRL+O
Allows you to Alter a selected Godown in Multi Godown screen.
