https://help.tallysolutions.com/docs/te9rel55/Tax_India/VAT/vat_purchases/interstate_pur_zero_rated.htm
Recording an Invoice for Zero Rated Interstate Purchases
You can record interstate purchases of zero rated goods by selecting the nature of transaction Interstate Purchase - Zero Rated.
This nature of transaction is provided for Assam, Bihar, Chandigarh, Chhattisgarh, Delhi, Goa, Haryana, Himachal Pradesh, Jharkhand, Kerala, Madhya Pradesh, Maharashtra, Odisha, Puducherry, Punjab, Rajasthan, Tamil Nadu, Uttarakhand, and Uttar Pradesh.
To record an invoice for zero rated interstate purchases
2.    Enter the Supplier invoice no. and Date.
4.    Set the option Is Against C Form? to No in the Party Details screen. This option appears only when the State selected is other than the State selected in the Company VAT Details screen.
5.    Select the purchase ledger grouped under Purchase Accounts with the Nature of transaction set to Interstate Purchase - Zero Rated by selecting the required Party Entity/Org. Type.
6.    Select the stock item. Enter the Quantity and Rate.
7.    Set the option Provide VAT Details? to Yes. In the Statutory Details screen
o     Select the Form to issue, and enter the other relevant details as shown below:
Note: The options in the above screen appear based on the State selected in the Company VAT Details screen.
o     Press Enter to save and return to the purchase invoice.
8.    Press Enter to save.
