https://help.tallysolutions.com/docs/te9rel55/Tax_India/VAT/Recording_Adjustment_Entries.htm
Is an adjustment entry required for balancing the output VAT with the input VAT amount?
It is not necessary to record an adjustment entry to adjust output VAT with input VAT amount whenever VAT is payable, because the VAT amount is auto adjusted from release 5.0 onwards.
