https://help.tallysolutions.com/docs/te9rel55/Tax_India/VAT/Delhi/Changing_PreDefined_Period_in_Annexure_2A_and_2B.htm
Changing Pre-Defined Period to Monthly in Annexure 2A and 2B
The periodicity of e-VAT annexures can be changed to monthly, for filing monthly returns.
To change the pre-defined quarterly period to monthly in Annexure 2A and 2B
1.    Go to Gateway of Tally > F11: Statutory Features.
2.    Set the option Enable Value Added Tax (VAT)? to Yes.
3.    Enable the option Set/alter VAT details? The Company VAT Details screen appears.
o     Select Delhi as the State, as shown below:
o     Click F12: Configure on the Company VAT Details screen. The Configuration screen appears.
o     Enable the option Show VAT applicable from? as shown below:
o     Change the Periodicity of e-VAT Annexures to Monthly, as shown below:
o     Press Ctrl+A to accept.
Annexure 2A and 2B can now be generated for monthly return as well.
