https://help.tallysolutions.com/docs/te9rel55/Tax_India/TDS/TDS_Deductor_branch_division_details.htm
Specifying Deductor Branch or Division Details
You can use the option available in the TDS Deductor Details screen to provide deductor’s branch/division details.
To specify the deductor’s branch or division details
1.    Go to Gateway of Tally > F11: Features > Statutory & Taxation.
2.    Set Enable Tax Deducted at Source (TDS)? to Yes in the Company Operations Alteration screen.
3.    Enable the option Set/alter TDS details? to display TDS Deductor Details screen.
4.    Enter Deductor branch/division, as shown below:
5.    Press Ctrl+A to save.
