https://help.tallysolutions.com/docs/te9rel55/Tax_India/TDS/Setting_Zero_or_Lower_Rate_for_TDS.htm
Setting Zero or Lower Rate for TDS
You can set up zero or lower rate related to TDS by enabling the necessary configurations under F12: Configure during ledger creation.
To set zero or lower rate for TDS
1.    Click F12: Configure in the Ledger Creation screen.
2.    Enable the option Allow advanced entries in TDS masters.
3.    Press Ctrl + A to save the details. A new option Use Advanced TDS Entries will be available.
4.    Enable the option Use Advanced TDS Entries.
5.    Select Applicable in the Set/Alter Zero/Lower Collection.
6.    Select the required TDS nature of payment from the List of TDS Nature of Pymts.
7.    Select the Section Number.
8.    Enter the Certificate No./ Date.
9.    Enter the Applicable From date.
10.  Enter the Applicable To date.
11.  Enter the rate of TDS in the TDS field.
12.  Repeat steps 6 to 10 for the required TCS nature of goods.
13.  Select End of List to exit the screen.
14.  Press Ctrl + A to save the details.
15.  Press Ctrl + A to save the party master.
