https://help.tallysolutions.com/docs/te9rel55/Tax_India/TDS/How_to_recompute_TDS_returns_%28Rel_5.0_onwards%29_.htm
Recomputing TDS Returns
Any transactions or masters is modified after saving the returns then you need to recompute the returns to have changes in the report.
To recompute
Go to Display > Statutory Reports > TDS reports > Form 26Q/27Q > F5: recompute > Click F7: Saved as revised or F6: Overwrite.
