https://help.tallysolutions.com/docs/te9rel55/Tax_India/TDS/Enable_Surcharge_Details_for_TDS.htm
Enabling Surcharge Details for TDS
You can enable surcharge details applicable for TDS by using the F12: Configure option.
To enable surcharge details for TDS
1.    Go to Gateway of Tally > F11: Features > Statutory and Taxation.
2.    Enable the option Set/alter TDS details.
3.    Click F12: Configure.
4.    Set the option Enable Surcharge Details for TDS to Yes.
5.    Press Ctrl + A to accept.
6.    Enable the option Provide surcharge details.
7.    Enter the surcharge details, as required.
The TDS Surcharge Details screen appears as shown below:
8.    Press Enter.
9.    Press Ctrl + A to accept.
