https://help.tallysolutions.com/docs/te9rel55/Tax_India/Excise_Mfg/Setting_Excise_Details.htm
Setting Excise Details (Excise for Manufacturer)
Excise details such as tariff, non-dutiable classifications, MRP and so on can be configured at company level or as separate masters.
To set excise/tariff details
1.    Enter Tariff name.
2.    Enter HSN code.
3.    Select the Reporting unit of measure.
4.    The cursor skips the field Valuation type. To modify it, click F12: Configure and enable the option Allow Modification of Valuation Type.
5.    Enter the Rate of duty.
6.    Press Enter to save.
To create non-dutiable classifications
1.    Go to Gateway of Tally > Inventory Info. > Excise Classification > Create.
2.    Enter Tariff name.
3.    Enter HSN code.
4.    Select the Reporting unit of measure.
5.    Select the Type of tariff as Non-Dutiable.
You can record excise details based on the date of applicability for different periods, if required.
To modify valuation types when creating a dutiable tariff
1.    Press F12: Configure
2.    Enable the option Allow Modification of Valuation Type?
3.    Press Ctrl+A to accept.
4.    Select the Valuation Type, as required.
To configure tax on MRP
1.    Press F12: Configure.
2.    Enable the option Allow tax based on MRP?.
4.    Set the option Calculate Duty on MRP in the Excise classification creation screen.
