You can generate Job Work Out Reports and get accurate stock positions by tracking material movement.
To view the Job Work Out Reports
Go to Gateway of Tally > Display > Job Work Out Reports
Job Work Out Reports are:
● Stock
'Job Work Out Reports Menu' has been shared with
