https://help.tallysolutions.com/docs/te9rel55/Job_Work/JI_Job_Work_In_Reports.htm
Job Work In Reports (Job Work In)
You can view Job Work In reports.
To view the Job Work In Reports
Go to Gateway of Tally > Display > Job Work In Reports
Job Work Out Reports are
     Order Outstandings
     Job Work Registers
     Stock
     Job Work Analysis
