https://help.tallysolutions.com/docs/te9rel55/Error_warning_message/split_incorrect_ledger_selected_in_allocation.htm
Incorrect ledger selected in the bank allocation screen (in Release 4.9.2)
Cause
This error occurs while saving a receipt voucher after altering the participating ledger in double entry mode in release 4.92, as the ledger name present in the Bank Allocations screen was not refreshing/updating with the modified ledger.
Solution
Upgrade the release from Tally.ERP 9 Rel 4.92 to Tally.ERP 9 Rel 4.93.
If you wish to continue in 4.92, you can resolve this error by the following procedure.
To continue in 4.92
1.    Click F12: Configure in the receipt voucher.
2.    Enable the option Use default for bank allocations?
3.    Press Ctrl+A to accept.
         Or
2.    Enable the option Use single entry mode for pymt/rcpt/contra?
