https://help.tallysolutions.com/docs/te9rel55/Control_Centre/Test_Completed_by_Employee.htm
Test Completed - Employee Assessment
This folder displays the list of employees who have completed their online tests.
To view Test Completed - Employee Assessment
1.    Select Test Completed folder.
2.    Press Enter.
The List of Employees screen appears displaying the list of employees who have completed their online tests as shown:
3.    Select the required employee.
4.    Click A: Answer Sheet. The Answer Sheet screen of the selected employee appears as shown:
5.    Click F1: Detailed. The detailed Answer Sheet appears as shown:
6.    Select the required question.
7.    Click D: View Details.
The Marks and Result for the selected screen are displayed in Answer Details as shown:
The following functions can be performed from this folder:
     F1: Detailed: Allows you to view the test details of the employees, such as, E-mail ID and Test ID.
     C: Add Comment: Allows adding comment to the selected employee.
     V: View All Activities: Allows viewing all the activities of a selected employee along with the comments recorded at each of the process level.
