https://help.tallysolutions.com/docs/te9rel55/Banking/status_for_transactions_under_e-payments_for_dbs_bank.htm
What are the types of statuses available for transactions sent to bank under e-Payments for DBS Bank?
Once you send the transactions to DBS, the transactions are listed under Transactions sent to bank (unreconciled) with any of the following status:
     Submitted - When transactions are sent to the bank.
     Verifying - Transactions are under verification by the bank.
     Authorisation pending - Transactions accepted by the bank and is available for authorization on the bank's portal.
     Authorised - Transactions are authorised at the bank's portal by the authorised person.
     Processed - Transactions are processed by the bank.
     Failed - Transactions failed (due to incorrect sender account no., unregistered TSS ID with bank, and so on).
