https://help.tallysolutions.com/docs/te9rel55/Banking/is_tallynet_id_mandatory_for_enabling_e-payments.htm
Do I need to configure Tally.NET ID for enabling e-payments?
No, you do not need to configure Tally.NET ID for enabling e-payments. If you are an account holder in DBS bank, and you wish to send transactions to bank from Tally.ERP 9, you must log in to your company with your Tally.NET ID, which is registered with the bank.
