https://help.tallysolutions.com/docs/te9rel55/Banking/error_code_31001.htm
Error Code 31001: Payment request could not be processed. Try again later.
Cause
This error appears either because the bank server is not responding or the connection to the bank server is timed out.
Solution
Re-send payment instructions to the bank after some time.
