https://help.tallysolutions.com/docs/te9rel55/Banking/changing_bank_details_during_entry.htm
Can I Change the Bank Details of the Party During Voucher Creation?
Yes, you can change the bank details of the party while creating the voucher. For example, you can change the IFS code.
