https://help.tallysolutions.com/docs/te9rel55/Advanced_Features/Advanced_Inventory_Features/Enabling_Rate%28Inclusive_of_Tax%29.htm
Enabling Rate (Inclusive of Tax)
When defining the price of the item you can include the tax rate.
To enable Rate  (Inclusive of Tax)
1.    Go to Gateway of Tally > Inventory Info. > Stock Items > Create/Alter > F12: Configure.
2.    Set Allow inclusive of tax for stock items to Yes.
3.    Press Ctrl+A to go to the Stock Item Alteration screen.
4.    Set Is inclusive of duties and taxes? to Yes.
5.    Enter the Rate of Duty, as required.
6.    Press Ctl+A to save the ledger.
