https://help.tallysolutions.com/docs/te9rel55/Advanced_Features/Advanced_Accounting_Features/deleting_a_budget.htm
Deleting a Budget
A budget can be deleted.
To delete a budget
1.    Go to Gateway of Tally > Accounts Info. > Budgets > Alter.
2.    Click D: Delete.
