https://help.tallysolutions.com/docs/te9rel55/Advanced_Features/Advanced_Accounting_Features/Enabling_Cost_Category.htm
Enabling Cost Category
Cost categories are useful for organisations that require allocation of revenue and non-revenue items to parallel sets of cost centres. Enable cost categories in F11 features to create and use cost categories.
To enable cost categories
1.    From Gateway of Tally > Click F11: Features > Accounting Features.
2.    Enable the option  Maintain Cost Centres?
3.    Enable the option Maintain more than one payroll or cost category?
The Company Operations Alterations screen appears as shown below:
4.    Press Ctrl+A to save the Company Operations Alteration screen.
Cost Categories are now enabled for the company.
