https://help.tallysolutions.com/docs/td9rel54/tdlreference/gcc_schema.htm
GCC VAT Changes in Schema
This page includes the list of new objects added and the existing object changes.
Object
Details
Company
Method
CompanyNameNative
CompanyAddressNative
CompanyEmirateNative
CompanyCountryNative
CmpTypeOfSupply
CmpTaxAmountTolerence
Stock Item
Method
GVATIsExciseAppl
Voucher
Method
PlaceOfSupplyState
PlaceOfSupplyCountry
IsOverseasTouristTrans
Ledger Entry
Method
GVATExciseRate
OrigPurchParty
OrigPurchPartyAddress
OrigPurchInvNo
OrigPurchInvDate
OrigPurchValue
OrigPurchNote
SupplyMargVal
