https://help.tallysolutions.com/docs/td9rel54/td9/working_with_projects/load_tcp_file.htm
Loading the TCP file in Tally
You can attach the TCP file in Tally in the Tally.ini file file or in the Tally.ERP 9 configuration screen.
To load TCP files in Tally.ERP 9
● Attach the .tcp file in Tally.ini file.
o Once the TCP file is compiled and generated, copy the TCP file link, and attach it in Tally.ini file.
o Open the Tally.ini file found in the folder where Tally is installed, and set User TDL = Yes .
o Uncomment the line by deleting the semicolons (;;) in tdl, and enter the name of the TCP project ( For example , TestProject.tcp)
o Save Tally.ini , and start Tally to run your customized application.
Or
● Attach the .tcp file in Tally.ERP 9 configuration screen.
o Start Tally.ERP 9 .
o Go to F12 Configuration > ProducT & Features .
o Click F4: Manage local TDLs .
The TDL Configuration screen appears as shown below.
o Enter the details and accept the screen.
