https://help.tallysolutions.com/docs/td9rel54/td9/working_with_projects/opening_projects.htm
Opening Projects
In Tally.Developer 9, you can open a new project or file, or the most recent project or file.
To open a project
1. Go to File > Open Project .
2. Select the required project, and click Open . The selected project is displayed in the Project b rowser.
3. Double-click a file in the Project browser to view it in the Editor window.
The Project name and the Main program file name is displayed in bold.
Note: If you select .txt or other files, the Output window displays Invalid Format File message.
To open a File
● Go to File > Open File .
● Select the file to be opened in the Editor window.
Note: When you open files of other projects, they are displayed under Other Files in the Project browser.
To open the Recent Projects
● Go to  the File > Recent Projects .
● Select the required project.
To open the Recent Files
● Go to File > Recent Files .
