https://help.tallysolutions.com/docs/td9rel54/td9/using_the_editor/basic_tdl_report.htm
Basic TDL Report Template
In TDL, each interface to be designed, needs to follow the basic report template which starts from Report and ends at the Field.
The template is shown in the image below:
