https://help.tallysolutions.com/docs/td9rel54/integration-capabilities/significance_of_tags.htm
Significance of Tags
Following are some significant tags that are required for requesting any info from Tally.ERP 9. The tags are divided into two categories:
● Header Tags
● Body Tags
Header Tags
Header tags are enclosed with the tag <HEADER> and </HEADER>. These tag gives all the header information.
<VERSION>
It gives the version of the messaging format. The tag <VERSION> is a mandatory tag which is used in Header tags.
<TALLYREQUEST>
TALLYREQUEST tag specifies the type of request. This tag is vital as it determines the response required. The permissible values for this tag are Import, Export and Execute. This value further determines the range of values required for this tag.
Import
Import is specified when we want Tally to import data from the XML fragment to Tally. i.e Tally validates and saves the data. A request is made to Import Data or File which can be specified within the subsequent tags.
Export
Export is specified when we want to retrieve data from Tally. A request is made to Export Data, Collection, Object, Function, etc. which is specified within the tag <TYPE>.
Execute
Execute is specified when we want to execute some TDL actions in Tally.ERP 9. Here the request is made to Execute TDL Action which can be specified within the <TYPE> tag.
The following table describes the value of <TALLYREQUEST> tag.
Request Type
Action
Comments
Import
Set
Requesting recipient to import the data.
Export
Get
Request  for  Exporting  Data  from other end.
Execute
Run
Request for executing the action in Tally
The TYPE attribute of this tag can be used to identify specific instance of an entity. The attribute Type can be used like the following example:
<HEADER>
<VERSION>1</VERSION>
<TALLYREQUEST>EXPORT</TALLYREQUEST>
<TYPE>OBJECT</TYPE>
<SUBTYPE>Ledger</SUBTYPE>
<ID TYPE="Name">ABC India Pvt. Ltd. </ID>
</HEADER>
TYPE
ID - Value
Qualification
DATA
Name of the Request / Report
Not Applicable
COLLECTION
Name of the Collection
Not Applicable
OBJECT
Object ID or Name of the Object
Object Identifier Attribute
ACTION
Name of the Action to be performed - As of now, only the action Sync is introduced
Not Applicable
FUNCTION
Name of the Function to be executed
Not Applicable
<STATUS>
The <STATUS> tag is applicable only for Response. Value within this tag indicates success or failure of the request made. Possible values are SUCCESS (1), FAILURE (0).
Example for a Failure Response
<ENVELOPE>
<HEADER>
<TYPE>DATA</TYPE>
<ID>All masters</ID>
</HEADER>
<BODY>
<DESC>
</DESC>
</BODY>
</ENVELOPE>
Failure Response
<ENVELOPE>
<HEADER>
<STATUS>0</STATUS>
</HEADER>
<BODY>
<DATA>
</DATA>
</BODY>
</ENVELOPE>
Note: At the time of request within <HEADER>...</HEADER>, all tags must have appropriate value. Only <SUBTYPE> is optional and can be used where applicable. In case of Response Header has only two tags i.e., <VERSION> tag to indicate the version of the messaging format and <STATUS> tag to indicate Success / Failure.
