https://help.tallysolutions.com/docs/td9rel54/dict-mgr/using-reference-dictionary/using_reference_dictionary.htm
Using Reference Dictionary
Single word strings, that have been translated, are used to compile a Reference Dictionary . A Reference Dictionary is a useful reference material for the translator, who can use it for translation activities in the future.
Bring up Reference Dictionary
To open a Reference Dictionary from a working dictionary
● Go to File > Open Reference Dictionary .
The Reference Dictionary screen appears as shown below:
By default, the Dictionary Manager tool creates a file with language name, and extension .DCR. The file <language name>.dcr is available in the Ref folder.
For example, if the language is Sanskrit, Dictionary Manager tool will create the file Sankrit.dcr.
