https://help.tallysolutions.com/docs/td9rel54/td9/help/help_menu.htm
Help Menu
The options available in Help menu in Tally.Developer 9 are explained in this topic.
● About TallyDeveloper: Click About Tally.Developer 9 to view the Tally.Developer 9 splash screen.
● TallyDeveloper Help: Click this option to launch the Tally.Developer 9 Help.
● TDL Samples: Click this option to load the Samples project, which is a comprehensive  set of TDL files demonstrating all aspects of the TDL language.
● Steps to Run TDL Samples: Click this option to open the document Steps to Run TDL Samples , which specifies the required steps to execute the Samples project.
● TDL Reference Manual: Click this option to open the document TDL Reference Manual , which is a comprehensive guide to the TDL language.
● Support Centre: Click Support Centre to post queries on Tally.Developer 9 and TDL. For more information on Support Centre , click here .
