https://help.tallysolutions.com/docs/td9rel54/dict-mgr/operations-in-dictionary-manager/setting_dictionary_preferences.htm
Setting Dictionary Preferences
You can set the dictionary preferences by going to Tool > Preferences .
The Preferences screen appears as shown below:
In the Preferences screen, the following options are available:
● Load the last opened dictionary whenever the dictionary manager is launched.
● Automatically load the current language keyboard.
● Activate phonetic keyboard whenever Dictionary Manager is launched.
