https://help.tallysolutions.com/docs/td9rel54/tdlreference/func_sysinfo.htm
System Function: SysInfo
Use the function SysInfo to retrieve system related information, like system date, operating system version, and so on. $$ SysInfo accepts one parameter at a time, out of the 19 explained below.
Syntax
$$SysInfo : <Parameter>
where <parameter> is one of the values explained in the table below.
No.
Parameter
Description
Example
ApplicationPath
The folder path where the current copy of Tally is running.
C:\Tally.ERP9
2
CurrentPath
The data path configured in tally.ini , residing in the application path.
C:\Tally.ERP9\Data
3
SystemDate
The system date.
27-May-2017
SystemTime
The system time.
18:27
5
SystemTimeHMS
The system time in hh:mm:ss format.
18:27:36
6
SystemName
The system name.
TallyClient2
7
IsWindows
Checks whether the system has Microsoft Windows operating system.
Yes
8
WindowsVersion
The Microsoft Windows version with the build number.
6.2 (9200)
9
WindowsUser
The name of the Windows user who has logged in.
geetha.ram
10
IPAddress
The IP Address of the system.
192.168.1.17
11
MACAddress
The Media Access Control Address of the network adapter in the system.
0720fhac027a
12
RunningIPV4Addr
The currently running Internet Protocol Version 4 address.
192.168.1.17
13
RunningIPV6Addr
The currently running Internet Protocol Version 6 address.
2001:db8:85a3:8d3:1319:8a2e:370:7348
14
IsOSx64
Checks whether the operating system is 64-bit.
Yes
15
IsAdmin
Checks whether the operating system is running in Admin mode.
No
16
TallyinAdminMode
Checks whether Tally.ERP 9 is running in Admin mode.
No
17
UACStatus
Checks whether the User Account Control is enabled.
Yes
18
SystemProxySettings
The proxy settings in the system.
192.168.1.17:8000
19
ModuleName
The folder path and file name of the current application.
C:\Tally.ERP 9\tally.exe
