https://help.tallysolutions.com/docs/td9rel54/td9/working_with_projects/tcps_support_earlier_versions_of_te9.htm
Generating Irreversible TCPs to Support Earlier Versions of Tally.ERP 9
You can build irreversible TCPs which are supported by earlier releases of Tally.ERP 9 Release 5.4.
To build irreversible TCPs
1. Load the earlier releases of default TDL (tdlserver.dll).
2. Generate the TCPs by selecting Irreversible under Compilation Formats .
