Will the new irreversibleTCPs are compatible with earlier releases of Tally.ERP 9?
https://help.tallysolutions.com/docs/td9rel54/td9/working_with_projects/tcps_compatible_with_earlier_releases_te9.htm
Will the new irreversible TCPs be compatible with earlier releases of Tally.ERP 9?
No, the enhanced irreversible TCPs are only compatible with Tally.ERP 9 Release 5.4 and above.
