https://help.tallysolutions.com/docs/td9rel54/td9/working_with_projects/irreversible_tcps_in_td9_rel54.htm
Generating Irreversible TCPs in Tally.Developer 9 Release 5.4
You can generate the new format of irreversible TCPs in Tally.Developer 9 Release 5.4.
To generate the new format of irreversible TCPs
1. Load the Default TDL of Tally.ERP 9 Release 5.4 or higher.
2. Select Irreversible in the Compilation Formats section of the Project Properties screen.
