https://help.tallysolutions.com/docs/td9rel54/td9/working_with_projects/compatibility_of_irreversible_tcps.htm
Compatibility of Irreversible TCPs
The compatibility table for irreversible TCPs is explained in this topic.
Tally.ERP 9 Releases
Compatibility of TCPs compiled using Tally.Developer 9 Release 5.4
Regular TCPs
Irreversible TCPs
New Format
(using Default TDL of Tally.ERP 9 Release 5.4 or higher)
Old Format
(using Default TDL of Tally.ERP 9 Release 3.6 - Release 5.3.8)
Tally.ERP 9 Release 5.4 and higher
Tally.ERP 9 Release 3.6 to Release 5.3.8
