Enabling Order Processing
https://help.tallysolutions.com/docs/te9rel62/Voucher_Entry/Order_Processing/Enabling_Order_Processing.htm
To enable purchase order, sales order, and job order processing in Tally.ERP 9, you have to activate the required features in F11: Features (F2: Inventory Features).
Enable the following features in the Order Processing section:
●     Enable purchase order processing
●     Allow Sales Order Processing
●     Enable job order processing
Note: When Enable job order processing is set to Yes, the options Maintain multiple Godowns and Use material in and out vouchers get enabled automatically.
