Create a journal voucher for the increase in tax liability.
To create a journal voucher for interest payable
Note: You can create a journal voucher from Gateway of Tally > Display > Statutory Reports > VAT > select the VAT form.
2. Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o Select Type of duty/tax as VAT.
o Select Increase of Tax Liability as the Nature of adjustment.
o Select the option Interest in Additional Details field.
Note: Based on the selection made for Nature of adjustments, the Additional Details option will appear or disappear.
o Press Ctrl+A to accept and return to the voucher.
3. Debit the expense ledger and enter the amount.
4. Credit the ledger grouped under Current Liabilities.
5. Press Enter to save.
'Increase of Tax Liability (Karnataka)' has been shared with
