You can override the assessable value and tax in an invoice using the procedure in this topic.
To override the assessable value and tax in an invoice
1. Go to Gateway of Tally > Accounting Vouchers > F8: Sales > Tax Invoice.
2. Press F12: Configure to configure the sales invoice.
To select sales ledger for each item and modify the tax details in the invoice
1. Set Use common ledger A/c for item allocation to No.
2. Set Allow modification of Tax Details in VAT to Yes.
3. Press Ctrl+A to accept the screen.
3. Select the party ledger in Party's A/c Name option.
4. Enter Party Details, as required.
5. Select the Name of Item from the List of Stock Items.
6. Enter the Quantity and Rate.
7. Select the sales ledger in Accounting Details screen, and press Enter.
8. Press F12: Configure in VAT Details screen.
To enter assessable value and tax rate in the VAT Details Configuration screen
1. Set Allow override Assessable Value? to Yes.
2. Set Override tax rate? to Yes.
9. Select the Classification/Nature in VAT Details screen.
10. Enter the required Tax Rate and Assessable Value. The VAT Details screen appears as shown below:
11. Accept the VAT Details screen, and Accounting Details screen.
12. Select the VAT Ledger.
Ledger must be grouped under Duties & Taxes in which the options:
● Set Type of duty/tax to VAT.
● Set Percentage of Calculation to 0.
13. Set the option Provide VAT Details? to Yes/No, as required. The sales invoice appears as shown below:
14. Press O to override the invoice with the changed assessable value and tax rate.
'Overriding Assessable Value and Tax in Invoice (Karnataka)' has been shared with
