Once you send the transactions to DBS, the transactions are listed under Transactions sent to bank (unreconciled) with any of the following status:
● Submitted - When transactions are sent to the bank.
● Verifying - Transactions are under verification by the bank.
● Authorisation pending - Transactions accepted by the bank and is available for authorization on the bank's portal.
● Authorised - Transactions are authorised at the bank's portal by the authorised person.
● Processed - Transactions are processed by the bank.
● Failed - Transactions failed (due to incorrect sender account no., unregistered TSS ID with bank, and so on).
'Status of Transactions under e-Payments for DBS Bank' has been shared with
