Data Management Exceptions and Resolutions
We have listed the possible data management exceptions you can encounter along with easily-to-follow solutions.
Exceptions for Masters
Exceptions | Solutions |
Parent group is missing |
To resolve this issue, perform the following:
The exception is resolved. |
Invalid Attendance Type |
To resolve this issue, perform the following.
Attendance/Production Type used in Calculation Type is invalid |
Mismatch in Unit between parent group and subgroup/master |
From date is later than To date under Period of Budget |
To resolve this exception, perform the following:
From and To dates are missing under Period of Budget |
Formal name contains invalid characters |
This exception is resolved. |
Name of voucher numbering series is not provided/invalid |
Formal name and Symbol are the same |
Bill Date for Bill-wise breakup of Opening Balance is missing |
Parent group is set as Cost Centre |
Mismatch in Unit of Stock Items |
Conversion factor of Compound unit is invalid |
Referenced master is missing |
Name is same as the alias or duplicate aliases are used in the master |
Name or alias of the master is the same as in another master |
Number of decimal places is more than 4 |
Master name is missing |
Exceptions for Vouchers
Cheque No. is not within Cheque Range/Invalid Cheque Range/Mismatch in Cheque Range |
No accounting or inventory entries are available |
Due Date of Order is missing in Item Allocations |
Incorrect Ledger selected in Bank allocations |
